SRS Malfunctioning after removing the seat
Old Jul 11, 2011 | 11:16 AM
rexi01's Avatar
C 350 (2008)
Hey guys,
I removed both drivers and passenger's seat the other day to detail my car and when I put them back together, I have two new messages pop-up regarding front left/right SRS malfunctioning. Does anyone know if you need to reset something, I checked the wiring and it looks ok!
Old Jul 11, 2011 | 11:21 AM
lingnoi's Avatar
2018 C180 9G
I guess you didnt disconnect the battery when you did this?
Just clear the fault codes with Star Diag or Bosch tester and errors should not come back.
Regards, L
Old Jul 11, 2011 | 11:23 AM
rexi01's Avatar
C 350 (2008)
Regards, L
Would it help if I disconnected the battery and connected again (I dont have Star Diag or Bosch tester).
Thanks for your reply
Old Jul 11, 2011 | 11:39 AM
lingnoi's Avatar
2018 C180 9G
Nope, that wont do. Must clear codes through obdII port.
Old Jul 11, 2011 | 04:47 PM
Red_Demon08's Avatar
08 C350, mars Red, Pano, PII, M.Media, Ipod. 18" AMG rims
i got the same problem.. i was told it was 500 dollars to fix it and i diddnt do bc i knw there tryin to rob me... i wish there was another way to go about this
Old Jul 11, 2011 | 05:25 PM
rexi01's Avatar
C 350 (2008)
Does anyone know any other way beside taking it to the dealer or using the diag tools? (Would the warranty cover that? I only have 45k on it)
Old Jul 11, 2011 | 05:46 PM
aprince2die4's Avatar
08-C350 black/black
I've read that AutoZone will read and and maybe clear OBDII codes, so you might give them a try if you have one local to you..
if not try this..
http://www.autozone.com/autozone/acc...questid=681790
Old Jul 11, 2011 | 05:54 PM
jmf003's Avatar
'03 SL55
The SRS fault is not an OBD2 code so an OBD2 reader cannot reset it. You need a Star system or the equivalent.
$500 is a ridiculous price to pay for resetting. It takes all of 5 minutes to take care of it.
Maybe look for an independent shop or a friendly forum member with a Star system. If you lived near Ann Arbor I'd be glad to help.
Good luck!
Old Jul 11, 2011 | 06:00 PM
08-C350 black/black
Good luck!
Good to know...Thanks for the clarification.
Old Jul 11, 2011 | 06:19 PM
rexi01's Avatar
C 350 (2008)
I called the dealership and they said it should still be under warranty, so they will inspect it for free. hopefully they won't charge me "fine print" fees..
Old Jul 11, 2011 | 07:19 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Just keep silent about how you caused this and maybe they won't charge you. And when the SRS fault warning is on, the system is off. No airbags or belt tensioners.
Old Jul 13, 2011 | 07:04 PM
rexi01's Avatar
C 350 (2008)
took the car at the dealer and they reset it for free. they did ask me if i had detailed it, but i kept my mouth shut.
thanks everyone for the input.
Old Jul 13, 2011 | 10:39 PM
RLE's Avatar
RLE
SRS warnings
Regards, L
You don't have to disconnect the battery. Just keep the key out of the slot.
