- Mercedes-Benz C-Class: How to Jump Start Mercedes-Benz
Step by step instructions for do-it-yourself repairs
Browse all: Specifications and General Maintenance
Car not starting. Help needed
I've got an automatic 2008 c220 cdi (w204) and it has stopped working today.
I unlocked my car and got in and put the key in and turned in and there is no power going through at all. The dash lighting don't even light up apart frm the mileage which iz always displayed. The headlights don't work etc but the cd player does work so I'm confused. When I unlock the car and turn the key the only thing that happens is that the car makes a low beeping sound for a few seconds and that's it.
Does any1 know what the problem could be?
Could it have anything to do with the ignition switch?
You can also check battery voltage by going into dyno mode.
Try jump starting in the correct fashion. Make sure that the ignition key is withdrawn when you connect up the donor battery .
If you can jump your car and drive it there last i checked they will even install it for free with a battery tender so you won't loose your settings.
Then have your voltage regulator checked.
You cannot replace the battery with a conventional lead-acid type so don't even try.
Try to jump your car or charge the battery. And bring it right to a walmart, pep-boys, autozone, whatever you have. They will do a free battery test.
