Tire sensor
Old Jul 23, 2011 | 08:44 AM
NJBenzC300's Avatar
2011 C300 4MATIC Sport
Tire sensor
Last night my sensor went on then I put air in and it was fine. So, this morning while driving to work the sensor went in again so I took it to a tire shop to check it. They found a small hole and patched it up. My questions is why hasn't the tire signal on the dash turned off yet? All the tires read the correct tire pressure.
Old Jul 23, 2011 | 12:37 PM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
with some systems they reset after driving 20 or so miles, etc...
Old Jul 23, 2011 | 12:42 PM
NJBenzC300's Avatar
I haven't driven it for 5 miles yet so I'll give that a shot first.
Old Jul 24, 2011 | 10:23 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
You can manually reset it on your instrument cluster after you inflate your tires with the correct PSI level. I can't tell you exactly the step by step sequence but Im sure you can find it by browsing through your instrument cluster.
Old Jul 25, 2011 | 05:52 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
get a little psi guage and go to a free air station and set the air to whatever psi u prefer on ur particular setup on all four tires. Then use ur steering wheel arrows and go into settings I beleive and there is tire pressure monitor. click down arrow and it says reset? say yes to the current values and it resets the psi to that level u just put in ur tires. after that it goes off only if it drops below that level. If its a 2010-2011 its almost the same but the dash will show the actual psi of all 4 tires right on the cluster, same deal tho
Old Jul 26, 2011 | 08:22 PM
IllusionX's Avatar
2006 C230 6spd > C300 4Matic
I've been having this issue. To reset, put the key and turn to second notch, radio on, etc just don't turn the car on. Go to settings in the instrument cluster, tire pressure, click down twice to where it says reset tire monitor with current values. It will reset, turn the car off then turn it on and the light will be gone. I'm pretty sure mine is a faulty sensor or the receiver, been having nothing but issues.
