CarFax showing multiple early wheel alignments and "A suspension check"
Interested in this car, although I noticed the first few records within a couple thousand miles of each other wheel alignments were performed, as well as a suspension/steering check, do you think this could indicate a dreaded vibration or it pulling to one side? The last service record shows a Mercedes dealer balancing two wheels and a 4 wheel alignment.
If the car test drives good, and you can get someone to check/verify the suspension and alignment, you'd probably be ok. This particular car only shows tires being replaced once, correct? Also, all of the suspension/alignment work seems to have stopped a while ago.
