Please help. Can't unlock
For some reason I can't unlock my c300 2010 with the remote. When I press unlock the red light on the remote flashes but the car does not unlock or lock. This happens with both keys and I'm scared to leave it unlocked. I used the metal key fob but this is not ok.
Can anyone suggest a solution or diagnoses to this problem. Thanks.
Hopefully it's not the same for you though but here is the thread anyway just in case you come across the same problems. Good luck
https://mbworld.org/forums/c-class-w...-hate-pos.html
Coincidentally, one of my keys is acting up now, resulting in a failure to begin the startup sequence about half the time. Since the other key works normally after a two week substitution, I will likely be getting a warranty replacement soon. My factory warranty expires in October so I have just purchased an extended warranty at no small expense.
