Nitrogen filled tires worth it for hot climates?
(I've noticed that most gas station air spray out moisture? I'm pretty sure you don't want much water if at all in your tires, which may cause more pressure fluctuation?)
Was your pressure more stable over time with nitrogen?
Thanks.
When I got my winter tires I had the shop use nitrogen and monitored the pressure monthly during the "six-month" winter season. I saw a final drop of 1PSI in each when I was ready to swap to the summer set.
It's been mentioned many times that you do need to have the tires deflated first then inflated 100% with nitrogen to experience what many still deem as negligible effects.
And theoretically speaking, as the atmosphere is made of about 80% nitrogen, simply inflate the tires with 125% of your ideal PSI values, and let the smaller "unwanted" particles to escape, then you'll be left with your nitrogen-inflated tires. lol
