Navigation off Map
6 Attachment(s)
Hi All
I just retrofited Comand NTG4 in my C class C220 cdi 2009 (UK) I am getting no satellite fix Here is the Pictures from the Engineer Menu. Error Code 000200 and it is showing 12 Satellittes on the GPS information . Any suggestions please . |
Originally Posted by omark
(Post 4801363)
Hi All
I just retrofited Comand NTG4 in my C class C220 cdi 2009 (UK) I am getting no satellite fix Here is the Pictures from the Engineer Menu. Error Code 000200 and it is showing 12 Satellittes on the GPS information . Any suggestions please . EDIT: I now see the date stamp on the fix is 2000. So indeed no current fix ;) Try resetting the system, or another GPS antenna. |
I am in Europe , Glasgow UK
How do you reset the system . If the antenna is faulty , how is it showing satelittes. What I noticed is that there is no position of satellites in the GPS info pic numer six . Thank for your help |
Did reset the system , no change.Still same
(Post 4801597)
I ordered a new antenna and will let you know once I will try it
Thanks |
The lat/long disagree in two different screens. Maybe garbage? Where are you located?
Does anyone know what that antenna error code means? Did you have the dealer code the car to accept the NTG? Otherwise some stuff will never work properly. |
I am located in Glasgow Uk
No I never had any dealer code to accept Ntg How is this got to do with satellite reception Thanks for your help |
My understanding is that the car has to be "set up" by the dealer (or anyone who has it and the knowledge) STAR system. Without that the car's electronics don't talk to the new piece of equipment installed and still thinks the old set up is there.
Good luck. |
