DIY - replace fog lights for Luxury model
C220 T W204
Hi guys,
I didn't found the DIY for replacing the fog lights for Luxury (non-AMG) models and since I've done it recently I am posting here the steps. I have H11 bulbs for the fogs.
1. Remove the plastic pins from the wheel cover (I removed 3 pins to have more room)
2. Remove the plastic pin from down the front bumper
3. Pull the plastic cover to be able to insert your hand in the back of the fog light, then rotate the bulb and get it out
Hope it's useful.
P.S. You can get to the fog lights easier by leveling the car and removing the front wheels or by removing the front bumper. But it's more time consuming and doesn't worth it
Hope it's useful.
W204 C220 CDI Manual 2007 RWD Elegance
First of all thanks for the DIY, it works great for the right side. The question is what to do on the left where I have my washer fluid container and I simply can't access that bulb from the wheel side or from the bottom any suggestions?
