Aftermarket Wheel Thread
Wheels: Vossen CV2 20x8F +44 and 20x10R +55
Tires: Nitto Invo 235/30/20F and 275/25/20R
Suspension: H&R Super Sport springs with 5mm shim pads
More photos can be found here:
https://mbworld.org/forums/c-class-w...-out-w204.html
![](http://farm7.static.flickr.com/6173/6138965258_0ae5cebcd1_b.jpg)
![](http://farm7.static.flickr.com/6200/6138424737_f38aa0b0a3_b.jpg)
![](http://farm7.static.flickr.com/6166/6138970774_056de76e22_b.jpg)
![](http://farm7.static.flickr.com/6186/6138966646_1b840d439f_b.jpg)
hey im thinkin of the same set up, i just wanted to make sure that there isnt any inner or outer rubbing anywhere. Do you have any fitment or rubbing problems either in the inner lining or outer fender of any sort? Sorry for al lthe questions but i just wanted to ask someone with experience.
#33
Former Vendor of MBWorld
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Thanks! You can see his full gallery here! Also you can email me at mike@vossenwheels.com with any questions!
http://www.vossenwheels.com/CarGalle...VSCV2-624.aspx
VVS-CV2 - Matte Graphite / Gloss Graphite Lip - F:20x8.5 / R: 20x10
![](http://www.vossenwheels.com/Gallery/FileUpload/Gallery/l_Mercedes%20Benz_C%20Class_VVSCV2_414.jpg)
#34
1 Post
2012 E350 RWD
![Aftermarket Wheel Thread-1318619581.jpg](https://mbworld.org/forums/attachments/c-class-w204/380958d1542321735t-aftermarket-wheel-thread-1318619581.jpg)
Shot with an iPhone. I will use my camera later on.
Tires are stretched. Didn't need that much but since I'm gonna go lower , I figured I should do it anyways. I know I will get negative comments about that and I'm prepared for it. Hey, at least they aren't green
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#37
'11 C300 Sport 4Matic, 911 Turbo, Fiat Abarth, Ram CTD
![](http://i200.photobucket.com/albums/aa125/nguyenl4o8/1318619581.jpg)
Are they BBS's are reps? Either way it looks awesome!
#38
1 Post
2012 E350 RWD
Thanks guys!
Post I made are in the picture thread stickied up top.
Nankang NS2 up front and Hankook V12 in the rear. Reason why I went with different tires are because NS2 run narrow and I wanted something that would give me clearance when turning the wheel all the way. I think I could have went 225 instead of 215 in the front and cleared with these. I may have made the mistake of running 225/40 in the rear because now there's certainly a big gap between the tires and fenders. This was all basically a test fitment but I am in search of shorter springs to go lower to minimize it so it all works out in the end I guess. Specs are in the link I posted below as well as how stretched the rear are.
https://mbworld.org/forums/4874698-post1901.html
#39
Loonie those BBS LMs look amazing.
Best 18" setup I've seen on a W204 so far.
After seeing your pics I'm thinking of getting H&R coilovers to drop my car a little more.
Props
Props
#40
1 Post
2012 E350 RWD
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#41
2008 C300
I run Mandrus Stuttgarts:
Front- 20x8.5 ET42 wrapped with Goodyear F1's 245/30-20
Rear- 20x10 ET 54 wrapped with Goodyear F1's 285/25-20
Dropped on Eibach Pro kit
Pics up later.
Pics up later.
#42
Thanks coming from a guy owning a C63 estate. Love the estate AMG you got. Wished we had them in the states otherwise I would have picked up a C-Class one. H&R are great and I love them even though they don't give me the drop I desire but I'm sure you will. They are a little bit on the stiff side but not too much ![drive](https://mbworld.org/forums/images/smilies/driving.gif)
So you're into the stance scene. What drop are you running atm? -40mm?
I have a set of -20mm springs and the front is quite low (due to the lip) but I would like to improve the fitment and run some slightly stretched tires.
I have 15mm spacers in the front and 10mm spacers in the back but I need narrower tires for the rear.
I'm planning this setup for the summer:
F: 8,5Jx19 ET45 +15mm spacer 215-225/35/19
R: 9,5Jx19 ET54 +10mm spacer 245/30-35/19
Here are two recent pics:
http://41.imagebam.com/download/st-S...7/image-4.jpeg
http://66.imagebam.com/download/ztys...2/image-2.jpeg
#45
1 Post
2012 E350 RWD
Thanks. Well the estate is nothing special here in Europe. 75% of C63s in Germany are estates.
Regardless, loving the C63. To be honest, I don't know how low my set up has given me. I know my front isn't as low as my rear but hopefully I can change that in the near future. As much as I want to go static, I'm pulling the plug and going air.
Offsets are before the spacers correct? If so, that'll be aggressive and I can't wait to see it. Ran similar offset in the front but rubbed during turns with 18x9 +30 215/40/18. Changed it back to +45 and running 5mm spacers now. Don't know if the AMG has more room in the wheel well or not but hopefully it'll work out.
#47
1 Post
2012 E350 RWD
That looks ****ing awesome! Love the color. One question though. Why did you go with the larger profile? Ideal profiles would be 35 in front and 30 in the rear for 19s.
#48
'09 C350 4M, '11 Sienna SE, '84 VW Jetta GLi
#49
And those are aftermarket leds tails, yes?
#50
2009 Evo X 420 AWHP, 2012 C250 Sedan
