Warranty Work
1. Transmission seems to be delayed in shifting from Reverse to Drive occasionally. Ill shift the gears and press the gas as i would on any other car and then the car would rev up for a second or so then engage the gear and jump and drive off. Occasionally has a hard shifts between 1st and 2nd
2. A/C has a odd smell at times when first turning it on
3. The rubber in front of the command center (idk if it would still be called this since i dont have the GPS) is coming unglued.
4. The A-pillar on the passenger side of the car has a broken clip that i just noticed about two days ago.
5. Are software updates or firmware updates covered? Is there any known ones for 09 C350's?
6. Alignment but i know this I have to pay for out of pocket.
Any help would be greatly appreciated or if you guys know of any other issues i should have looked at that are common problems.
As for #2, they may tell you to change one or more a/c filters (perhaps the cabin filter).
#5: folks have had mixed results when attempting to get a firmware update. I and a few others were able to get it done under warranty (on a COMAND system though), while others didn't have the same luck. Some dealers don't know about it, others may not be willing to put the time unless there is an issue that the firmware update would address.
However, if you had the navigation (if you get GPS added on, you would have the UMI NAV+4, since you don't have COMAND) and are looking for a map update, you will definitely have to pay for that.
As for alignment, you are correct- you will need to pay for it. I don't know about your dealership, but the ones over here frequently have specials going on, so it may be worth checking their website for coupons / offers. If you bought your car from the dealership, you may also receive some introductory coupon on parts/service as a thank you.
And most importantly, CONGRATULATIONS and welcome to MBWorld!
Cool thanks man, and thanks for the welcome... From your experience at your local dealership, how good care does MB take of there customers?
#2: This is also a problem that I had. There were others on the forums that had similar complaints about the odor. Occasionally when I turned my AC on, the car would smell like sweaty socks. It was really nasty. However, there is a cleaning process that the dealer can complete to remove the mildew growing in the ventilation system. MB knows it's an issue and will cover it under warranty. Afterwards, they recommended that I run my Heat w/AC on at full blast for 10 minutes once in a while to remove excess moisture from the system.
#5: Firmware update are free if it fixes a problem. But I don't think they'll do it just because you want updated firmware.
Congrats on the new car and welcome to the forum!
You tell them that you need your tcu updated because there is a dangerous lag between reverse and drive. Tell them that you constantly are reving the engine by accident because the car hasn't shifted into drive or vice versa. I had my 09' c350 tcu updated.
Your cabin filter will probably need to be replaced. At your dime
You should have no problem getting this fixed under warranty
If you have the factory Ipod adapter, just tell them to update your command for the low volume. That should get the latest firmware.
They'll have no issues charging you for this.
1. Transmission- Should be covered by warranty as long as there is no damage to it or the car hasnt been crashed.. Which shouldnt be a issue to warranty it.
2. A/C- She says they will check it out but i might need to purchase a A/C Filter ($130)
3. The Rubber on the command center- Says shouldnt be a problem to cover under warranty as long as it doesnt look like its been peeled off (to me it looks like the heat might of damaged it)
4. The clip on the A pillar- She said that this shouldnt be a problem getting taken care of.
5. Software updates- She said this will be checked when they update the software on the transmission..
Any other things you guys think i might should have looked at just let me know as in any common problems... Ill be bringing it in on Friday 10/14
