Northern climate rust spray
However, if there is a lot of gravel where you regularly drive, putting a tar-based undercoating around the wheel wells, under the door sills and under the trunk will protect damage to the factory coating. While you are at it, do the trunk in the spare tire well and under the trunk carpeting, plus around the rear quarters. This will make the Benz much quieter. The shop performing this work must absolutely cover and protect any suspension and brake parts.
Leave it alone.
