Shaving offsets ?
Old Nov 11, 2011 | 08:08 PM
hitokiri89's Avatar
2010 c350
Shaving offsets ?
I want to get a set oz futura's or keskin kt's if cant find the right size but for both sets the highest offset is 35 . I was told with the right tire size i could run a 35 offset but im lowering my car in a few days and i dont think it will work . Which brings me to ask this question , if i shave the offset to be more positive will i run into a lot of problems later on and also is this even possible on the futura as its a 3 piece wheel ?
Old Nov 11, 2011 | 08:21 PM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
should be possible and i dont see why you would ever run into problems later. all that is shaved is the center hub which raises the offset. this is most likely the answer to fitting those wheels but i'm not an expert. maybe B.Gorman can chime in.
Old Nov 11, 2011 | 08:23 PM
hitokiri89's Avatar
2010 c350
Is it at all possible to run a 35 offset once i lower ?
Old Nov 11, 2011 | 08:33 PM
the only issue i can think of now with shaving is slight caliper clearance if anything. i do not own a W204 and everyone alway says to not run more than 45 f 50 r. You do have the few that are willing to put the work in to fit wider widths and lower offsets. I have a W209 and most run an 8.5 32 f 9.5 35 offset rear. Few are using spacers with 22-25 offsets. I am willing to put the work in to fit different sizes. I custom ordered a set of Work wheels @ 19x9+21 with 15mm spacer to clear calipers making it 19x9+6 front and 19x10-0 rear. I was expecting some major work but surprisingly the rears were perfect and the fronts will need some work. If you are willing to make it work just do it.
Old Nov 11, 2011 | 08:35 PM
hitokiri89's Avatar
2010 c350
You think with the right tire size and rolling my fenders I'll be ok ?
Old Nov 11, 2011 | 08:40 PM
if caliper clearance is not an issue than i dont see why not.
Old Nov 11, 2011 | 08:45 PM
hitokiri89's Avatar
2010 c350
Seems like plan so far than , I take my car in a few days to be lowered , guy does fender rolling so I'll let him do the measuring in regards to caliper clearance .
Old Nov 11, 2011 | 08:54 PM
which wheels did you end up getting?
Old Nov 11, 2011 | 08:57 PM
hitokiri89's Avatar
2010 c350
Didint get them yet , I want oz futura's but the price has to be right . If not those than keskin kt1 .
Old Nov 11, 2011 | 09:06 PM
oh ok i just figured cause you said you would have your guy do the measuring in regarda to the caliper clearance. that would be after you have the wheels and decide to shave them.
Old Nov 11, 2011 | 09:08 PM
hitokiri89's Avatar
2010 c350
I can get the wheel measurements from keskin , shouldn't be far off as they reps of the futuras
