HELP! Where to buy C63 Rep Wheels?
Old Dec 8, 2011 | 09:34 PM
wsong1987's Avatar
C300 sport
Can you guys tell me where to buy
good 18" C63 rep weels for my 2010 C300 sports?
Old Dec 8, 2011 | 10:27 PM
Sportstick's Avatar
Another round of ICE
http://www.powerwheelspro.com/shop/
Old Dec 8, 2011 | 11:49 PM
CKreep's Avatar
C300
Alot of those wheels are the wrong offset
Old Dec 9, 2011 | 08:32 AM
Sportstick's Avatar
Yes, different than the exact OE specs. But, I've learned that great outcomes can work with some minor adjustment. Check out my prior thread after I bought 44 offset AMG reps from them:
https://mbworld.org/forums/c-class-w...g-17-reps.html
Old Dec 9, 2011 | 10:00 AM
Peabody's Avatar
http://www.mercedesbenzwheel.com/c-class-w204-2/
Old Dec 9, 2011 | 12:47 PM
CKreep's Avatar
C300
On those wheels the 40+ is correct the 35s stick out to much
Old Dec 9, 2011 | 03:05 PM
Sportstick's Avatar
The spec for the car is 47 front (7.5" width) and 58 (8.5" width) rear, but with the same 8" width fore and aft, the 44 offset does work well, as you can see in the photos. With a 9.5" width, the offset would need to be higher to prevent poking out any further, as you note.
Old Dec 9, 2011 | 03:16 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
with a 9.5 rear wheel a +45 is flush with outside fender, stock look is +54 or higher rear and + 45 or higher front wheel. Theres no problem using same size all around if you wanna be able to rotate, anything mid forties or higher is plenty, in a 8" wheel +40 would work too
Old Dec 9, 2011 | 04:13 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
i already started a thread that shows the best most OEM looking 19" c63 reps...
bro get these: https://mbworld.org/forums/c-class-w...rence-oem.html
http://www.ebay.com/itm/19-WHEELS-ME...item5d309eadeb
Old Dec 9, 2011 | 04:16 PM
bhvrdr's Avatar
2012 e350, a BMW, an Audi, a Camaro
I think what they're trying to let the original poster know is that in the link you posted NONE of the c63 18" wheels they sell are in an offset that will work. They are et35 and not like your 17s that came in et44.
Cheers! Mike
