Cigarette light battery tender okay?
Old Dec 28, 2011 | 10:24 PM
LandSeaAir's Avatar
2008 W204
Right now I have my C on a cigarette lighter battery maintainer and am wondering if it is okay?
I figured I'd leave it on for the night, but now I'm wondering if I should take it off. I have to leave the key in the first position because otherwise it wouldn't charge, this must be because the cigarette lighter is off when the key is off.
I know Merc sells a tender and I see it has the cigarette light adapter so I assume its okay?
Interestingly enough the tender isn't pictured as an accessory under vehicle care to the C-class in the build your own MBusa as it is the E and S.
I hope this is okay
Old Dec 29, 2011 | 12:45 AM
Kaewen's Avatar
GLC250 Coupe
whats a tender? i've always thought it was something soft and cuddly...
Old Dec 30, 2011 | 12:38 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
I hope this is okay
It isn't OK. Leaving the key in position 1 will kill the battery overnight and I question whether the battery maintainer could keep ahead of it. And it would be pointless not to mention you couldn't lock the car with the remote.
if you think you really need this you need to get the battery connector with the quick disconnect cable.
There are many of these devices on the market.
Old Jan 1, 2012 | 03:58 PM
nyca's Avatar
I agree, get it out of there - the lighter adapter on these tenders are only designed to be used on cars where the lighter receptacle is hot when the car is off.
