Brake Pads Thickness
Looking forward on some inputs.
Drive in good health!
James
Lower Limit thickness for both is 3mm .
If you have built in warning devices your car will alarm when they are a little lower but in my opinion the dealer is correct in saying they should be changed. It is their policy to change them if they will wear out before the next scheduled service. Common sense.
All the best James.
Next stop for me is to see if the car is equipped with brake pad warning... I believe it does. I'll let you know asap.
Conventional thinking would have the front pads wearing at a faster rate.
It may be conservative drivers wear the rears faster ?
Thank you James.
