Change Ipod Integration To Aux Input?
. The thing is if you have ipod integration you should be able to change songs through your dashboard easily. Once you switch to aux you have to manually do it.
. The thing is if you have ipod integration you should be able to change songs through your dashboard easily. Once you switch to aux you have to manually do it.Trending Topics
If you truly want ONLY the Aux cable input, pull out the iPod Integration Kit and this will allow the Aux cable to be used again. If the iPod volume into the Aux cable is too low after removing the Ipod Integration, purchase a PHP Audio Sound Shocker from:
www.phpaudio.com
www.phpaudio.com
