Flickering Tail Light, help please
Anyone know if its a SAM issue, or just caused by the wirings heating up? Or does a malfunctioning SAM cause the wires to heat up which in turn causes in the light to dim?
It also always seems to be the right taillight that has the issue.
I guess I could replace the harness but my question is what caused this? I don't want it to happen again.
I was thinking maybe my license plate LEDs are possibly connected to the brown wire and are causing this? But the other cars with the same problem do not have aftermarket LEDs.
You can do this yourself if you have the patience to get the pins out of the connector. Or you can just snip them off one by one and strip the wire and buy 7 new pins for like $8. The latter is definitely easier. You just need a wire stripper and a set of needle nose pliers to clamp the pins onto the wire. The former requires a lot of patience and three arms. Be careful not to mangle the pins if you don't have replaements if you go that route.
Remember which goes where. I did them one at a time and inserted them into the corresponding hole on the new connector.
It is caused by low quality connections used on the Bulb assembly. the brown wire is earth and that carries the heaviest current. You only need a few ohms resistance on that connection and the pin gets very hot. Enough to melt the plug.
One preventative cure is to clean the male pins on the bulb holder with a pencil eraser and contact cleaner every few months. It is one thing MB should be looking closely at as no one wants a fire in their trunk.
It is very important to make good connections from old wire to new one, or you may be adding a source of resistance and heat. I recommend soldering the connections.
As well, the wires are small and difficult to tape. I sealed mine with heat shrinkable tubing from The Source (or Radio Shack) so that they won't short circuit at a later date.
Good luck.
Also the fact it's on the right hand side is troubling. That's where the emergency kit goes, and it sits up to the wire harness making it even hotter. I'm going to not put anything there and give the plug more air.
HHTSA Recall # 14v-177
You are due a refund if you had to pay for this repair.
Of course free of charge!
