iPod control?
Old Feb 13, 2012 | 11:29 PM
briiannj's Avatar
C
iPod control?
Hey everyone, so I recently traded in my BMW for my first merc, and I got an 09 with the flip out MM navi and everything.. Though that's not the case since i cannot control my iPod or stream audio via a2dp BT.
I searched the forum and google and I keep hearing about a UMI kit and other types of updates but so far it seems like those are for people looking to retrofit the entire navi into their car which I already have..
All I want is the cable so that I can control my iPod via BT streaming or the screen and steering wheel, if not atleast the latter. I cannot seem to find exactly what I would need.. It seems like it's not the $1700 UMI that I need, or is it? I read somewhere that it's simply a $200 cable to install?
Hopefully somebody can point me in the right direction, right now I'm just confused from what I've read. Thanks!
Old Feb 13, 2012 | 11:49 PM
CKreep's Avatar
C300
Do you have the iPod cable in the glove box? If so connect and go to disc and with the command scroll down to AUX you should be able to scroll your ipod with the end call button on your steering wheel.
Old Feb 14, 2012 | 09:08 AM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
The Anystream will allow bluetooth streaming in most Mercedes. You can see it on our site. cartronics.com
Old Feb 14, 2012 | 10:20 AM
briiannj's Avatar
C
I only have the AUX input for a 3.5mm cable, so there isn't a dock connected anywhere specific to iPods. So would the controls still work with an AUX cable?
Old Feb 17, 2012 | 09:57 AM
DigitalKnight's Avatar
2011 IS350C
Exclamation HELP!!!
I have the iPod cable in the glove box but for the life of me I can not get the AUX to show up anywhere????
Old Feb 17, 2012 | 11:57 AM
STRES's Avatar
2008 c300 sport
once you are in the audio tab re highlight audio press the mouse and scroll down to aux took me a while to figure out, MB isnt very intuitive/user friendly i find myself using the dash buttons and the mouse let me know if that helps
Old Feb 17, 2012 | 12:20 PM
2011 IS350C
Question
Would you happen to have or could you snap a photo of the screen? When I am in audio I only have "Radio", "CD", "CD Changer" and "CD/MP3" as choices.....
Old Feb 17, 2012 | 12:22 PM
STRES's Avatar
2008 c300 sport
do you have a ipod cable in the glove box? or an aux jack?
Old Feb 17, 2012 | 02:26 PM
2011 IS350C
It is an iPod cable. I have plugged in a iPod touch, and iPhone and an iPad 1 and iPad 2 and nothing happens.
Old Feb 20, 2012 | 06:58 PM
2011 IS350C
Would a MB stealer be able to figure out what or how the iPod connector works? Or if it is an aftermarket will they just say "good luck"?
Old Feb 20, 2012 | 07:49 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
With the Screen Open:
1.Select CD
2.Use the knob to select Aux
3.Press the Hang-Up button on the steering wheel to select Playlist, Artist, etc.
4.Use the Up/Down arrows on left side of wheel to scroll though choices.
5.Press OK
Old Feb 21, 2012 | 11:53 AM
STRES's Avatar
2008 c300 sport
select audio
then aux
this is how i get there i guess it depends on the model of head unit you have
Old Feb 21, 2012 | 05:29 PM
2011 IS350C
Thank you for the pictures... mine is way different but it does not show an AUX as a selection. Will have to have it checked out by a 12V guy I know see if he can figure it out.
Old Oct 30, 2012 | 10:30 PM
Adrian97c's Avatar
2010 Mercedes-Benz C-300, 2011 Kia Optima 2.0T(GDI)
2010 C300 sport base model and i'm having the same issue, iPod cable in glove box and only choices on HU are "CD, Radio"
Old Oct 30, 2012 | 11:36 PM
E350 Sport/ML350RWD
Do you have the flip up screen?
Audio20- No Flip up screen
Audio50/Command- Flip screen
https://mbworld.org/forums/5414507-post3.html
Old Oct 31, 2012 | 01:09 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
had same problem...you have to press cd and then scroll through the options for aux
Old Oct 31, 2012 | 11:56 AM
E350 Sport/ML350RWD
https://www.youtube.com/watch?v=0e8saGUMPyU
Old Oct 31, 2012 | 12:20 PM
Adrian97c's Avatar
Originally Posted by AkaSigFreak
I drive the optima to work cuz I travel an hour total daily & optima turbo gets 32mpg!!
Soon as I get home I'm gonna test the iPod! Thx for the YouTube upload!! I'm not used to being a forum newb, so I appreciate your help.
