Reverse Camera with Guide Lines - Aussie
Old May 23, 2014 | 01:57 AM
chrisdean's Avatar
W205 C200 AMG Line Premium
Only a fool would totally rely on a camera whilst reversing, as with parking sensors they are there only to assist.
Old Jun 2, 2014 | 12:49 AM
Petomaani's Avatar
MB C200 K
Originally Posted by turbo97se
This is an old thread that came up in a google search I did. It is likely you need a DAS 2010 with DAS developer enabled. Once you go in, you should be able to get to the menu below and enable the CAN ID 34 to get your lines … I managed to enable mine
Here is the menu. The CAN ID 34 needs to be turned on and the SRVC static guiding lines need to be set.
Could this help in my problem - my problem is that I have not SRVC option under reverse camera selection on engineering menu, I just have reverse camera installed/not installed options?
Old Aug 20, 2014 | 02:42 PM
zaverdi's Avatar
C63 AMG
i know it is an old topic but i am also facing problem with my installation...
i do have the guidelines but i lost the pop-up function of the screen when i select the R...
Any help?
Old Aug 21, 2014 | 03:02 AM
chrisdean's Avatar
Apart from switching the camera on through the hidden engineering menu you also have to enable it from the general settings menu. No secret codes for that one but you should find more details in the handbook.
Old Jul 24, 2018 | 12:43 PM
ChazThePhoenix's Avatar
2019 GLC 350e
Originally Posted by StormTrooperZo
Don't know much about the c63 but just checking you guys looked on the second page in the engineering menu a lot of people missed the next page but if it's not there it is there
I was in the menu last night... I was on the HD parameters page...it says 1/18 but I could not figure out how to get to the other pages....I tried DOWN...nothing. It was stuck on option 1-7
what was I doing wrong? ah maybe RIGHT on the wheel?
Old Feb 18, 2019 | 11:18 AM
dc1989's Avatar
2014 C300
NEED YOUR HELP. DID YOU INSTALL A CAMERA TO THE FACTORY SCREEN??
I HAVE A 2012 C300 WITH NAVI AND ALL BLUETOOTH. WHAT ALL DO I NEED BESIDES THE CAMERA. FAKRA CABLE??
BEHIND THE FACTORY HEADUNIT DID IT HAVE A YELLOW RCA CABLE FOR THE CAMERA OR DID YOU NEED A FAKRA CABLE???
