will this size wheels fit my C300 4matic?
front 19x8 5/112 ET 45
rear 19x9.5 5/112 ET 53
If so what tire sizes do you guys recommend?
If you do that much driving you gotta ask urself something.......do I wanna buy tires every 6-9 months? Thats the reality my friend. U will get 20k-25k out of a set of 19s, you can prob go 25k but they will have no performance after 20k. If your hell bent on staggered this is the way it is, you cannot rotate them. If you go 8.5 all around u could run a small 3-5mm spacer out back to give u the look and still rotate them. It wont be as fat a tire when ur right behind the car lookin at the back end, but you will be able to rotate and get 30k+ out of a good brand. I used to drive alot and didnt care and just went all out, it only hurt when having to buy tires LOL, but I had hookups on tires and installs. The rears go faster than fronts, u can at least split it up and do them seperate so its not an all 4 wallet killer. Good luck let me know if you need any help
