Bluetooth audio
Old Mar 7, 2012 | 06:45 PM
Mikedivincent's Avatar
2010 c300
Bluetooth audio
Does anyone know of any adapter we can use to allow a BT enabled device to send music to the standard "command" type radio in a 2010 c-class?
Old Mar 7, 2012 | 08:31 PM
itsLoonie's Avatar
2012 E350 RWD
Does your car have the integrated iPhone adapter cable in the glove box? Mine does and I'm using this little device I got from eBay but cartronics sells it to. Looks like this
http://www.cartronics.com/images/AnyStream1.jpg
Just have to sync it with your Bluetooth like you do your phone and it'll resync every time you turn your car to on position.
You can find it here at their site. Should be the 5th item under Bluetooth music stream.
http://www.cartronics.com/MBNew.html?MBClass=C&VIM=1
Old Mar 8, 2012 | 09:28 AM
ltcinf's Avatar
2010 C350, 2011 BMW 328xi
I have it and it works great. Actually get better sound quality the I did with a direct hook-up-can't explain why but I do. Easy to use. You still use your OEM bluetooth for phone calls. Once you sync up though you need to adjust setting so it is only for audio streaming, not for phone calls otherwise I found that the two blue tooth systems were competing and one would not hook up--usually the MB one.
Old Mar 8, 2012 | 02:51 PM
itsLoonie's Avatar
2012 E350 RWD
Really? Never had that problem. Synced up the anystream bluetooth and I have never touched it once again (besides when other passengers want to sync to play their music). Whenever someone calls, music just fades and calls goes through. Music resumes when I hang up.
Old Mar 8, 2012 | 03:48 PM
ltcinf's Avatar
It was only on the initial use then everything was fine. It might be just my Droid that cuased the issue.
