First Spark Plug Change
Old Mar 10, 2012 | 12:18 PM
matthew121170's Avatar
2012 E350 - Cabrio; 2017 GLS 450
Hey everyone -
Just did my first spark plug change around 118K miles or so. I'll upload some photos and share with everyone what I did. It was fairly easy to do, just needed a T-30 to take the coil packs off with, a regular socket wrench fitted with a 5/8" socket to take the plugs out with and a torque wrench to put them back in with. Taking them out was a bit of a struggle because they were in there very tight, but a little elbow grease and they eventually came out. As you are facing the motor, the left side is easier to work on than the right side of the motor due to two hoses that run down the right side. I also found a cigarette butt in my filter box, so I guess my car has a smoking habit!
All in all, very easy DIY to do. Dealer wanted $330 to do it, i did it in about an hour with the air filters and taking some photos. Next time probably 1/2 hour to 45 min for both. Plugs ran me $62.04 (pre-gapped) and the filters were $22.43 a set. Air filters are Hengst and the plugs are Bosch Iridium Platinum. Next I'm going to tackle oil changes as soon as my oil and MityVac gets here.
Attached Thumbnails First Spark Plug Change-imag0157.jpg   First Spark Plug Change-imag0163.jpg   First Spark Plug Change-imag0166.jpg   First Spark Plug Change-imag0167.jpg   First Spark Plug Change-imag0172.jpg
Old Mar 10, 2012 | 01:06 PM
2012c350's Avatar
2020 C363 S / 2007 SLK55 / 2016 F150 4x4 / 1998 Cobra Convertible
Sounds rather simple. Curious if you notice any power improvement with the new plugs.
Old Mar 10, 2012 | 01:09 PM
No, nothing as of yet. I did reset the trip-odometer and we will see if there's any long term improvement.
Old Jan 12, 2014 | 06:22 PM
tiyyara's Avatar
W212 E350 4 Matic 2011
Torque on plugs?
How much torque did you apply to the plugs?
Old Jan 12, 2014 | 09:04 PM
nyca's Avatar
What is that setup with the gorilla tape on the ratchet end - you didn't have a locking extension, or did you need a wobble head to get to the plugs closest to the firewall? A little WD40 squirted into the plug hole and allowed to sit for a minute or so, usually makes it easier to break the thread - it can be scary when you do it, especially on the factory installed plug since they usually go in without anti-seize on the threads.
