H&R Coils
C300, 93tt RX7, 88RX7 Vet, 83RX7
H&R Coils
For those of you with H&R coil overs, do you find them a bit clunky in the front? Like almost a loose sound but they are not loose at all?
u gotta take the whole coil out as one unit and if u need to change the cap to the OEM one. Tighten the middle big nut up and then put back in as one unit. Tighten the tops good. there should be NO noise whatsoever. I grease all my pads and spring ends when I do springs/coils they are super quiet....
Yea, took everything out for safe measure. Re-did the middle nut and the top 3 torx bolts. Think it was just the middle nut that needed to be bolted down because there was some metal shavings when I looked at it.
