Remove trunk liner on 2010 C300
I am trying to remove the trunk liner on my C300. Can anybody give me step by step instructions on how to remove it. I'm especially having an issue with the hooks. Pictures would be fantastic!
'11 C350 '13 F150 lariat
everything is just pull pins, use a pulling tool or a cheap plastic set from autoparts store. Everything else is bolts, either torx or safety torx. Which hooks are messin u up? the ones at the corners by taillights? or the shopping bag hooks?
Thanks for the reply! I'm stuck on the shopping bag hooks. I believe I'm doing it right but I am scared to snap it off. Do you know how to take those off?
2008 C350 Sport
The hooks have a small piece that pulls out just above the hook. If you look close you will see the seam, just pry that out and the hook will pull out.
