PUDDLE LIGHT
Old Mar 21, 2012 | 12:21 PM
Dandan2012's Avatar
C250
PUDDLE LIGHT
Hi Guys,
My puddle light underneath the side mirrors does not work... how do i fix it? The sorround lighting in ON in the settings. Its a C 250 sedan, 2012..
Old Mar 21, 2012 | 03:16 PM
blue00r6's Avatar
2017 C43
is just one not working? or are they both not coming on..
Old Mar 21, 2012 | 05:07 PM
Dandan2012's Avatar
C250
Both not coming on.
Old Mar 21, 2012 | 07:09 PM
Memphis1's Avatar
'12 C300 4matic
i've seen the setting inside the dash cluster
Old Mar 21, 2012 | 07:55 PM
mfkl2's Avatar
2012 c250
use the controls on your steering wheel. use the arrows to scroll right to "settings" then go to "lighting" then scroll down till you see "surround lighting" and it should say Press 'OK' to enable/disable. if enabled the display should show as orange light coming from the puddle and fog lights. if its off then it will show as white. if still doesnt work then take it to your dealer.
Old Mar 21, 2012 | 07:56 PM
mfkl2's Avatar
2012 c250
and they only work at night when unlocking the car
Old Mar 21, 2012 | 08:11 PM
Dandan2012's Avatar
C250
Thank you both for your input. I did check the settings. Sorround lights are on. I am taking it to the dealer to check on it.
