19x9.5 in the front ?
Old Apr 5, 2012 | 04:31 AM
hitokiri89's Avatar
2010 c350
This possible with et48 up front ? Anyone got pics running this wide in front ?
Old Apr 5, 2012 | 04:54 AM
hitokiri89's Avatar
2010 c350
Lol funny gif but not sure how it pertains to my thread though .
Old Apr 5, 2012 | 01:21 PM
mangoango's Avatar
08 C350
The problem might be the wheel clearance on the inside of the wheel well (e.g. front strut). Plus you might need to run a 215/40 tire if your car is low.
I think it would look similar to Loonie's previous setup, except your front wheel would be sunken in by 0.47 inches and the tire would be stretched a bit more.
Old Apr 5, 2012 | 01:51 PM
hitokiri89's Avatar
2010 c350
Was looni running 9.5 ? I can always roll my fenders so poke doesn't bother me I just want to make sure the car will steer and handle correctly .
Old Apr 5, 2012 | 02:05 PM
mangoango's Avatar
08 C350
That pic was when his LM's were reverse mounted. Front wheel was 18 x 9, +30. (I think)
Old Apr 5, 2012 | 02:06 PM
itsLoonie's Avatar
2012 E350 RWD
In the picture I was running 9 +30. I rebuilt it back to 9 +45 because there was more poke in the front than the back which I didn't like. With 9.5" +48 you would get 9mm less clearance on the inside according to the offset calculator and 3mm poke on outside. I did rub when I had the offset +30 on tight u-turns and rarely on big dips.
Old Apr 5, 2012 | 02:14 PM
hitokiri89's Avatar
2010 c350
Do you think it will be an issue if I roll my fenders ?
Old Apr 5, 2012 | 02:16 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
9 is max. 9.5 is too wide, 225 is the lowest u can go in 19s w the proper weight handling, 215 wont do it. and u are on coils, not gonna work bro. Why dont u post up what wheels u kinda like maybe we can give u some leads. seems everything u r looking at is wront bolts pattern, offset, or size. U looking for a deal on used or for new? whats the budget I may have a line for you
Old Apr 5, 2012 | 02:20 PM
hitokiri89's Avatar
2010 c350
My budget is about 1200 , think is I'm looking for specific style that just never matches up . Five spoke wheel with a step lip 18 inch . Sounds simple but there are only few in that size , usually 16 and less but that's ridiculous lol .
Old Apr 6, 2012 | 09:16 PM
hitokiri89's Avatar
2010 c350
Decided I'm going with keskin kt1 , 18x8.5 et35 from 18x10 et35 rear . This possible for the rear ? Will be rolling fenders and stretching my tires so lips poke out from sidewall .
