Tire Pressure Monotor System is unavailable
If you have any knowledge on this system your comments are greatly appreciated! Thanks!
I've taken it to the dealer (LOKEY Mercedes) and they can't figure it out. Being that its spuratic and the stupid fault codes doesn't specify which wheel its coming from.
About the only thing that has changed since new are the tires, which are filled with Nitrogen. But I was getting the same fault before the new tires...just not as often.
Any suggestions?
Regards,
Kabala
2009 C300
Kabala, I haven't discovered a solution but I have a theory. I have to find the wiring diagram but I do recall the TPMS module (located under the spare wheel) and the right tail light sharing the same ground point. I never got around to separating them so they have their own grounds, but Im not getting the errors anymore *knock on wood*.
