"NO Audio"
Old Apr 9, 2012 | 03:37 PM
mlm1565's Avatar
c300 2010
"NO Audio"
i have a 2010 C300 with no audio, any suggestion what the problem may be?
Old Apr 9, 2012 | 05:39 PM
acr2001's Avatar
2012 C300 4Matic
You're going to have to be a hell of a lot more descriptive than that. Do you have COMAND? HK sound system? No audio AT ALL? have you tried every source? Are you still under warranty?
Old Apr 9, 2012 | 06:11 PM
Domm's Avatar
'08 Mercedes C300
Did you mute it? Thats all I can think of with the description.. ^+1
Old Apr 9, 2012 | 06:35 PM
papashango's Avatar
This and that.
Did it suddenly cut out? Did it never work?
From the amount of information you've given us, I am gonna say, did you start the car?
Old Apr 9, 2012 | 09:50 PM
warren2024's Avatar
2019 x350d
check the on/off switch for audio system, my wife accidently bumped ours while inserting a cd and simply turned the audio system off, had her worried until she got home because she thought she had broken something.
Old Apr 10, 2012 | 12:22 PM
mlm1565's Avatar
c300 2010
it has the command system with the navigation,that works, the radio turns on, we had a hail storm and i'm thinking, the amp must of gotten wet and fried it
Old Apr 10, 2012 | 11:38 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
So your car, unlike all the others here, leaks like a sieve?
Look for something obvious. Check your fuse sheet (in the trunk with the tools) for the fuse positions. Whether there is more than one fuse is unknown to me but it's a start.
But since the car is still under warranty, why not go to the dealer?
Old Apr 11, 2012 | 12:37 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Sounds like a trip to the dealer is called for.
Old Apr 11, 2012 | 02:31 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
If you have harmon kardon the amp is in the drivers side trunk boot, if you dont the amp is built into the head unit. U can get command in 2010 without HK option. There are fuses individually for HK system.
