NEED HELP ASAP!
Old Apr 14, 2012 | 07:03 PM
Thaa kiid Jlee's Avatar
2011 c300 4matic
NEED HELP ASAP!
Hello. I have two problems on my hand.
1. When ever I fill up gas, the handle never stops and the gas overflows. I took it to Mercedes and they said they could not find anything wrong. They filled it up to check. My mechanic friend said I should record it next time I fill up. I don't know what to do.
2. Randomly today my car made a weird noise. At first I thought it was my front lip rubbing on the ground, but it was not. It was a clunk noise. When I got to my friends' shop ( M.R Performance and Sticky Garage ), the owner of M.R Performance took it for a spin, jacked it up and said it is my suspension and I need to take it to Mercedes a.s.a.p. I recorded two videos. Can't get the second one up right now, but here is the first one. I apologize for my conversation ahead of time.
Thanks for your help!
Old Apr 14, 2012 | 09:16 PM
Domm's Avatar
'08 Mercedes C300
1. Did you make sure the gas pump was placed as far is it would go? I know I kind of had trouble with that because the rubber on the pump was too small and it would require additional effort get it situated correctly. I've never had it overflow, but there have been times where I had to manually grip it because it stops as soon as I begin pumping.
2. Do you not have warranty or something? Your car is a 2011.
Old Apr 14, 2012 | 09:23 PM
2011 c300 4matic
I do have a warranty but Mercedes is not open sunday
Old Apr 16, 2012 | 05:17 PM
2011 c300 4matic
the problem was a broken/ kink stabilizer rod
