Question on springs?
So you rub now without springs and if you get the H&R you will rub even more. What i recommend is 235/35 front and 255/35 rear and you should be good with no rubbing and also what kind of rims do you have?
Does it sound like it's rubbing on the fender or just the fender liner?
The stiffness of the H&R springs won't help and it'll just make your problem worse since it'll decrease the clearance between the tires and your fender/ fender liner.
