Engineering Menu Compiled Thread
Old May 13, 2012 | 02:33 PM
Jubair Ahmed's Avatar
2013 C350 Coupe 4M
Hi everyone,
I thought it'd be great to have a one stop shop for all the engineering menu goodies. I've only just begun playing around in there but I'll continue to edit this thread with new information as you guys post them. I've also compiled information from other threads!
To access the Engineering Menu:
Press and hold: "End call" + "#" + "1" at the same time for about 3 seconds
To access the Service Menu:
On the steering wheel press and hold "Accept Call" and "Ok" button for 3 seconds (this gives you access to service information, resetting the service status and turning on Dyno Plus)
-Turning on built in browser: HW Setting --> HU Parameter --> Browser --> On
-Turning on the SUV Compass: HW Setting --> HU Parameter --> Compass --> Change from non-suv to suv
-Turn on BT Streaming: HW Setting --> HU Parameter --> BT Audio --> On
-Turn on Rearview Camera (after custom install): HW Setting --> HU Parameter --> Rearview Camera --> Installed
-To reset DVD reginal code setting, press hang up + * + # where Remaining Changes is showing 0.
-Enable Music Search: HW Setting --> HU Parameter --> SDS Music Search --> On (works with USB, SD & HDD; not with iPod/iPhone)
-USB (not engineering menu) but can hold up to 32GB or 500GB HDD but must be in FAT32 (http://www.mercedes-benz-mobile.com/.../compare/~hdd/)
-Resetting after a failed update: At SW update menu when you pull down common knob. I did the following to clear this. Eject the CD, hit clr key beside common knob. Re insert the CD and during loading hit clr and press command knob many times. Abort icon will highlight and you can exit from there.
-Speed Limiter: HW Setting --> HU Parameter --> MPC Speed Limit (WARNING: not sure if this enables the feature where the car can detect road speed limits or if it programs a car speed limit (valet speed limit); additional info would be great).
-Increase Bluetooth Streaming Quality: SW Setting --> Telephone Info --> EC/NR --> Active
Old May 13, 2012 | 03:17 PM
Nesbocaj's Avatar
2012 C300 Luxury
Thank you very much!
Old Dec 21, 2016 | 02:19 PM
Rovel's Avatar
2007 E63 Amg
Originally Posted by Jubair Ahmed
Hi everyone,
Were you able to find out about the last option in the list?
What is it for? Is it for reading speed limits?
Old Jul 12, 2017 | 05:36 AM
fatjoe's Avatar
Smile
PLEASE UPDATE THE FIRST POST.
JAPAN mercedes engineering menu
START CALL + HASH + 1
NOT: END CALL
Old Jul 26, 2019 | 12:49 PM
Jires's Avatar
W166
It is for showing speed signs on the map screen when registered by the car. When option is off, signs are only visible for few seconds on the cluster display.
