Recent MB Dealer Service and an unfixable engine Whine.
2008 C300 6speed, 2015 GLK 250 2017 E400 wagon
Just some info on some recent Warranty work. Addressed some noise issues. 1st visit I complained about a squeal at cold start up. Fixed with new belt tensioner and got a new belt out of it. Upon Further inspection found my extension plugs leaking oil. (Cam cover) it was replaced. Also complained about low power steering fluid and noise. Nothing
found.
2nd visit 2 weeks later. Complained about low fluid and PS noise again. Diagnosis Leaking PS Oil Tank and PS pump bearing both replaced.
Now for the unfixable part. Still complaing of whining noise at take off at low rpm. The explaination I got is it's a normal sound from benz. Huh?? It a low rpm engine noise. Annoying as hell IMO? Doing a courtesy trans fluid check for me.
All this service was done on a 08 C300 Sport 6spd man/trans 60,000 kilometers. Can anyone chime in on this "normal" engine noise. Hope this info helped somebody. MB Oakville In Ontaro Canada was the dealer.
found.
1 Post
2009 C300 4Matic with Keyless Go
Get a second opinion from another dealer or mechanic. If you don't mind driving to Ajax, have it checked by an indy at MB Master (Jordan) at 415 MacKenzie ave.
These Stealerships kill me.
I have 30,000 miles on my 08 C300 Sport with a manual and don't have much of a whine. There is a tiny bit of gearbox noise, but that was present in my old transmission and the replacement transmission I got about 5,000 miles ago.
Of course, have it checked out since yours seems to be bad enough to bother you. Now that I am thinking about it, maybe I'm just getting old and deaf....
There's defiantly a whine noise in neutral and in gear 1st and most of second gear.And also can be heard when engine breaking (slowing down) at below 2500 rpm or so. Parts to the serpentine system have been replaced as mentioned in the OP. The noise I hear the SA can also hear. And was told it's quote... "normal" Lifter noise is more normal than this. It sounds PS related but after parts replaced I assume it's not the issue. BTW you had your man/trans replaced already on your c300 Yikess!
w204 C350 sport
I have that exact noise you're discussing. I have a '08 C350. The noise sounds like the belt sheaves/pulley might be out of line causing the belt to make noise. It seems to make the noise on cold starts and after I've been driving a little hard. I took mine to MB of Buffalo and the put belt lube on and it seemed ok but then the noise is back. I'll let you know what they tell me when I take it in.
hey DonjuanOriginal, i'm glad to find another user going to the same dealer. I own a GLK and has been quite unimpressed by the dealer's service. It's out of my way to get there but I thought it would be good to support an independant dealer. I've had problems after problems with my car and most of the time they thrug it off or make some stuff up. anyways. good luck with your fix.
That's when u make an appointment at another Dealer. I hope Burlington will have answers. Will post update.
2009 SL 6.3 AMG, 2011 E350 Convertible
I have a sl 6.3 amg. Same issue. I hear a whining sound at low rpms. it is driving me crazy. Dealer said they hear it but it does not affect the performance of the car....it affect the performance of the driver though.
My Problem in the end was my Power Steering Pump. The previous owner of my w204 had the PS Fluid Res. leaking. Ran the pump dry. Oakville MB replaced the Fluid Res but not the pump said it was a normal noise.... Bull****. It was the pump in the end. At low rpm was the most noise made.
w204 C350 sport
Then there was a high pitch whine; it sounded like I had a supercharger. The sound was through all rpm range in gear and neutral. Turns out the bearing went bad on the alternator. I had that replaced and now everything is good
Originally Posted by c3002008
Hi,
I have the same noise at low rpm as you mentioned. How much did it cost to replace PS pump?
Posted from Mbworld.org App for Android
