Fluctuating RPM while on the gas
Old May 20, 2012 | 11:57 PM
1DarkChaos's Avatar
2008 C300
Cool Fluctuating RPM while on the gas
Hey guys
I have a slight problem, my RPM is going up and down maybe 100 up and down while I am on the gas. Does that mean I have a vacuum leak?
I changed my air filter and exhaust recently, is there anyway to check?
Thank you!
Old May 21, 2012 | 12:18 AM
xXHotelCrazyXx's Avatar
2008 W204 Sport
You should take the air filter back out and make sure it is properly seated in the air box and that the air box is properly seated
Old May 21, 2012 | 12:45 AM
1DarkChaos's Avatar
2008 C300
I just lookd at it. There is one corner that does not sit flush but it's like that for both sides..is that normal then?
Old May 21, 2012 | 01:03 AM
2008 W204 Sport
It should sit flush, filter, and air box should all be seated properly
Old May 21, 2012 | 01:35 AM
1DarkChaos's Avatar
2008 C300
can a leaking exhaust lead to this as well?
Old May 21, 2012 | 01:41 AM
2008 W204 Sport
No, if you have your old filters, slave them in real quick and see what happens
