Gas
Old Jun 24, 2012 | 08:22 AM
Sommy's Avatar
C43
Gas
What grade/octane do you all use?
Does motor size dictate the choose- i.e. V6 versus turbo 4?
Old Jun 24, 2012 | 11:29 AM
jgcalderonperez's Avatar
2008 C300 4MATIC
I use Shell V-Power 93
Old Jun 24, 2012 | 11:30 AM
Richard2011's Avatar
2015 BMW M235i 6MT
Usually Sheetz 93, but sometimes I go to BP and get 93.
Old Jun 24, 2012 | 11:38 AM
Sportstick's Avatar
Another round of ICE
Costco premium with their new detergent package.
http://shop.costco.com/en/In-The-War...Locations.aspx
Old Jun 24, 2012 | 12:01 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
No it's not engine size, it's usually the compression/ratio and or turbo configuration that does. Most if not ALL MB gasoline engines require premium fuel. The higher the better. High Octane (H.O.) fuels delay their combustion thus allowing the piston to reach its full compression range, thus enabling the engine to take full advantage of the power stroke it produces. Lower Octane fuels (L.O.) burn and combust quicker (earlier) and at much lower compression and pressures, thus they're perfect for lower compression ratio engines but will pre-ignite too soon (pre detonation) during the compression stroke if used in high compression or turbo engines that require H.O. fuels.
Old Jun 24, 2012 | 01:28 PM
2012c350's Avatar
2020 C363 S / 2007 SLK55 / 2016 F150 4x4 / 1998 Cobra Convertible
Originally Posted by MBRedux
No not size, it's usually the compression/ratio and or turbo configurations do. Most if not ALL MB gasoline engines require premium fuel. The higher the better. High Octane (H.O.) fuels delay their combustion thus allowing the piston to reach it's full compression range, thus enabling the engine to take full advantage of the power stroke it produces. Lower Octane fuels (L.O.) burn and combust quicker (earlier) and at much lower compression and pressures, thus they're perfect for lower compression ratio engines but will pre-ignite too soon (pre detonation) during the compression stroke if used in high compression or turbo engines that require H.O. fuels.
You need to ensure that you use high enough to meet the recommendation. Higher the octane the more corrosive (not sure if that's the right word...) so you don't want to go higher than is necessary. Definitely don't want to go lower though because of pre-detonation as you've mentioned.
Old Jun 24, 2012 | 03:54 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
Always 91, mostly at Costco.
Knock sensor takes care of lower octane if it's not too low although I don't know what is too low.
Old Jun 24, 2012 | 04:03 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Sunoco/Exxon/Shell highest octane available (91-93 iirc)
Old Jun 24, 2012 | 04:08 PM
Domm's Avatar
'08 Mercedes C300
We have knock sensors? I thought Mercedes required unleaded premium, so knock sensors are only in vehicles that "recommend" premium.
Old Jun 24, 2012 | 04:59 PM
C300CA's Avatar
Actually I just guessed, as most less expensive cars have knock sensor, MB would normally have more stuffs than less.
I will ask service advisor about that.
When I took delivery, my saleman filled in with regular gas. He said it would not hurt. That was the only time with regular, I think is 87. There is no 93 around me, always 87, 89 and 91.
Old Jun 24, 2012 | 06:46 PM
MBRedux's Avatar
Correct! Here's something that might interest you all.
https://mbworld.org/forums/glk-class...ate-alert.html
Old Jun 24, 2012 | 07:36 PM
2012c350's Avatar
I notice the picture that your referenced post points to calls out RON rating. My C350's fuel door sticker doesn't mention the rating test. It does say 91, but doesn't say RON/MON/AKI. I'm assuming that all US pumps use AKI? I know that the pumps in Pennsylvania that I've been at use AKI.
Old Jun 24, 2012 | 08:29 PM
until the end's Avatar
2009 c350 arctic White pano. MM HK
im using 95 oct and i hear knocking some times i send the car to the delar and he seed nothing wrong and the knocking and bad small stile there ?? i did every thing without success
Old Jun 24, 2012 | 08:38 PM
MBRedux's Avatar
Yes, the USA uses R&M/2 or AKI rating index... both the same.
Old Jun 24, 2012 | 10:36 PM
BurdEmelry's Avatar
volvo
Old Jun 24, 2012 | 10:45 PM
Domm's Avatar
'08 Mercedes C300
It's called being cheap
