Any DIY guide for removing the whole backseat?
Hello guys
Can someone please tell me how I can remove the backseats completely? Bottom and back.
I found a few threads but they weren't like a detailed DIY...
Please?
Thank you!
Please?
Thank you!
Hi I done this yesterday pretty easy the bottom part you will have no prob just clips pull up first then push back while pulling up to disengage the clips
The back part bit more tricky first unscrew the hex bolts inside the cabin I think there was 4, 2 for the side of the seat and 2 for the rear seat belts, then take out the headrests, after that go to the boot lay on your back head as far as you can get in, if you look under the parcel self you will see a hole with a plastic tab inside it which move left and right with a screwdriver, that needs to be pushed to the right which undos the hook type mechanism there two of these, then simply lift out the back of the seat
If you local I could help you
