AZNoptics LEDs installed, showing the difference between LED amber turns and stock
We took delivery of the car at the gentleman's house in the lake travis area of austin. Place is absolutely beautiful--makes me want to move here!--here is a picture from a nearby restaurant we ate at (Oasis).
Here are the pictures from the drive home;
First thing i did when we got home was remove the front plate bracket--debating on getting the holes filled--and removing the god awful UT badge off the rear (sorry UT fans
).Also, since i cant leave anything well enough alone, i went ahead and ordered some LEDs from mike (AznOptics). I couldn't stand the fact that the rear turns are LEDs, the mirrors are LEDs, but the front turns are not. They blink soft under removal of load, out of sync with the other turn indicators, so I had to remedy the problem.
Yesterday i installed;
-License plate LEDs (5k 194s)
-Eyebrow LEDs (5k 194s)
-Amber turn signal LEDs (Amber festoon)
-Oem MB License plate cover
Started on the rears first--was fairly straight forward, albeit messy
Rears are in and lit
All buttoned up
Then i threw the plate cover on--of course it wouldn't be a REAL car project without drawing some blood, so i obliged.
Plate cover on
I cant stand the look of the rainbow texas plate, so i got a white/black custom plate on the way (no message just the plate). I think it will flow well with the iridium. It looks like this;
Moving on to the front;
Factory eyebrows
LED eyebrows
OEM on the LEFT, LED on the RIGHT (the color temperature & lumen output differential is much greater at night)
Then i moved on to the turn signals, to me, this was the biggest difference and my favorite result.
Here is the comparecent between the OEM filament turns and AZNoptics LEDs.
VIDEO (click it) OEM on the RIGHT, AZNoptics on the LEFT
VIDEO (click it) Everything completed and on
Everything buttoned up, Xenons on, Fogs on, Eyebrows on, Turn signals lit
Took the car out last night after the sun went down and everything looks 2x as good at night, very impressed with the results. Now to convince her on the OEM amg 18s, c63 diffuser, quad exit, magnaflow x, tune, etc, etc .... here we go again...
I did the exact same thing and added the same exact OEM license plate frame for $25:
Have not heard anybody mention this, but if you dont have the four point contact or four bolts on your license plate frame, you will definitely get the ridiculously cheap sounding rattle of the frame hitting the plate every time you close the trunk.
With the frame like you (and I) have, all you hear is a very nice and solid sounding "THUD" upon closure. Very crucial
Ur other half looks a lot like mine and got me thinking that she would really enjoy if I gave her my 2008 C350 when I upgrade to my next Benz
