Replacing battery, any issues that I should be aware of?
Old Aug 21, 2012 | 07:35 AM
japok_den's Avatar
2009 C300 4Matic with Keyless Go
I'm replacing the car battery later today. Are there any issues I should be aware of when I disconnect the battery (e.g. radio presets, folding mirror are the ones I'm aware of)? I'm reluctant to use those "memory saver".
Thanks in advance.
Dennis
Old Aug 21, 2012 | 04:42 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Here are a few, make sure the ignition is isolated ie key out , replace it with a battery of the same Amp Hours , make sure to attach battery vent pipe correctly,check for corrosion on cradle & smear a little petroleum jelly on terminals when finished to prevent corrosion.
Old Aug 21, 2012 | 08:16 PM
ggms16's Avatar
2009 C300 4Matic Sport
You will notice some issues with the auto opening and closing windows button, it will not work for a few hours, sometimes you won't be able to remotely open the trunk for a few hours also.. Nothing major.
Old Aug 21, 2012 | 08:17 PM
ggms16's Avatar
I see you have keyless go, so the 'KEY' instructions said before by Carsy won't apply
Old Aug 22, 2012 | 08:43 AM
japok_den's Avatar
Replaced the battery and other than adjusting the time/date and mirrors, no driveability issues or adjustments required so far.
Thanks for the tips!
Dennis
