W204 Side Marker LED Upgrade Problem
Old Aug 30, 2012 | 07:26 PM
kennedy_pilot's Avatar
2008 Mercedes-Benz C230
Hello All,
I just got a new pair of sexy side LED side markers for my 2008 C230 W204.
I installed them no problem.
BUT!!! Both turn on okay and.....then the drivers side flickers and turns off and the passenger one stays on...any ideas?
1) I reset the compunter by taking the battery out
2) I cleaned the socket
3) Tested the socket with the org bulb and passenger LED and works
Thx
Old Aug 30, 2012 | 07:28 PM
http://www.ebay.ca/itm/190699514304?...84.m1497.l2648
Is the picture/manufacture of the LED lights
Old Aug 30, 2012 | 08:36 PM
ob4rEaL's Avatar
c300 08
I posted this same issue not too long ago...no one gave me solutions...but sum1 gave some insight...said the leds prob don't need as much power being sent from comp. As original side markers did...I'm gonna see if my mech guy can hook it up to the computer program and perhaps change the voltage output to the side markers....
Old Sep 29, 2012 | 10:47 PM
MAK507's Avatar
C350
I got those same exact ones from that same exact seller. I'm returning them tomorrow. Totally pissed. The one that fits in the driver side is marked "R"... Weird. It blinks and then turn off. Getting error message to check the light. I really like them and I am going to buy from some other seller. Ob4rEaL is right. Whoever made these did not properly install the resistor. The LEDs are shutting off because they are getting too much power.
Old Sep 29, 2012 | 11:07 PM
05 MB Komp's Avatar
2010 C350 Sport
I am running a similar set of these with no problems.
Here is the seller I bought mine from. I have had two sets with no issues.
http://www.ebay.com/itm/DEPO-08-11-M...b20de2&vxp=mtr
Old Sep 30, 2012 | 03:19 AM
MAK507's Avatar
C350
Thanks. I'm going to give them a try. I was really sad when they lit on, flickered and died . lol
Does the same manufacturer make these or do these individual sellers have their own makes?
Old Oct 2, 2012 | 02:58 AM
kwinhtei's Avatar
C300 4matic sport
Maybe the product was damaged? If one works, the other one should work fine. Try switching the left and right?
Old Oct 2, 2012 | 03:03 AM
MAK507's Avatar
C350
Switching them would be impossible since it wouldn't fit (it would be like trying to fit a headlight in the opposite side). I'm returning the pair and ordered from the recommended seller.
Old Oct 2, 2012 | 03:10 AM
kwinhtei's Avatar
C300 4matic sport
I meant to say that you test to see if bringing the passenger side to driver's side would still work. Of course you can't attach it!
Old Oct 2, 2012 | 03:15 AM
MAK507's Avatar
C350
Haha I took you literally. Yes I tried and the plug didn't even fit properly into the socket. I didn't want to force it. Even with added pressure it still wouldn't go in.
Old Oct 2, 2012 | 09:32 AM
chriso's Avatar
10' C300 Sport
LEDs would not blink if they got too much power, they would simply give more light out, however blinking typically is caused by a poorly designed driver circuit that will cause oscillations; hence flickering. Simply put, these markers, although look nice, are flawed. Try to solicit feedback on other ones which are better constructed and do not have this problem.
Old Oct 2, 2012 | 03:31 PM
MAK507's Avatar
C350
I've seen many online with success. Unfortunately the OP and I coincidentally bought this from one buyer who doesn't care much about quality.
Old Oct 2, 2012 | 04:43 PM
05 MB Komp's Avatar
2010 C350 Sport
I would send them back and order the set that I posted. They must be made in different locations. I have had zero problems with mine.
Old Oct 2, 2012 | 04:53 PM
Frank41682's Avatar
2011 C300 4Matic
Hi guys,
I don't post too much on here, I'm pretty much just a reader. I have a '11 c300 4m and I love the idea of the LED markers. The only thing is I wish they made a set with amber LEDs instead of the white. I know alot of guys love the white but Im that guy who wants the amber. I have now the clear markers with the chrome amber bulb.
Do you guys think it would be hard to replace the LEDs with a little solder know how?
Also those of you guys who have the better depot ones. Would you say the the circuit board is easy to get to?
Thanks guys
Old Oct 3, 2012 | 03:44 AM
MAK507's Avatar
C350
I should have them here today this afternoon. Will see and update everyone on it
Old Oct 3, 2012 | 03:33 PM
MAK507's Avatar
C350
Seller definitely makes the difference! I went with the suggested seller and Wallah!
Before http://i1355.photobucket.com/albums/...ps4864a7b5.jpg
After http://i1355.photobucket.com/albums/...ps14173d41.jpg
http://i1355.photobucket.com/albums/...ps67269be2.jpg
Old Jan 26, 2013 | 09:17 PM
Savage c-300's Avatar
C300 Sport, MM, P1
Damn I ordered those same LEDs but I'm having the same issues here too.
Old Aug 28, 2013 | 06:03 PM
Maxima617's Avatar
2010 C300
Whats the seller name i can buy them from... i juss got a defective pair myself -_-
Old Aug 28, 2013 | 07:16 PM
joespeed29's Avatar
2013 C300 Sport
In for answers.
Being that this thread is a year old and given the lack of activity in these W204 threads I wouldn't hold my breath. Someone prove me wrong
Old Mar 16, 2014 | 07:38 PM
c250w4m's Avatar
C250 4matic
w204 led sidemarkers upgrade
Did your mechanic sort this out by chance? I have the same issue with the new led side markers. I tried to install on the drivers side, no luck! I tested them in the trunk light socket and they both work.
Old Apr 28, 2021 | 07:22 PM
Ben Hann's Avatar
w204
You need resistors (led decoders)
I know this thread is very old but it’s worth a try, when you upgrade the LEDs you need resistors also (aka led decoders) to prevent the flickering, going out, and possibly blown leds.
Old Apr 30, 2021 | 01:12 PM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
This one from Amazon is plug and play, no need for resistors and it doesnt flicker. However, this is amber colored LED if you are looking for white. Also, I had a problem with the first set and had 1 replaced under warranty.
https://smile.amazon.com/gp/product/B085LC6DZ5
Old Jun 6, 2021 | 09:23 PM
Tibbits's Avatar
C300
Funny that someone else finally figured this out and posted just a month ago. I just tried to put mine in today and the car cycles them on and off three times. I believe the issue is that they don't draw enough power for the car to realize they are on. And Mercedes in all it's infinite wisdom shuts the power off to prevent things like shorts from broken bulbs. Trying to come up with a method to trick the car into keeping them on. They were $15 and I think they look better on silver than the other options, so it's worth it to me to go tinkering. Couldn't be as bad as with my maxima when I shorted out the door locks by putting an oversized fuse in and then shorting a door light, could it? 🥴
Old Jun 7, 2021 | 06:47 PM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
Put motors cycle load resistor make sure you mount the resistor on the chassis metal
https://smile.amazon.com/gp/product/B08C7BBNSQ
Old Jun 14, 2021 | 12:07 AM
Tibbits's Avatar
C300
Sidemarkers fix
Decoders would've been either $10 to get in a couple days or $2 and up to three months from china. Sending the sidemarkers back for a cambus capable set would've been $5-$10 shipping and a week waiting for a refund and a new set. This was cheaper than both. It leaves two burnout points given there are two lights on each side now, but I would conject that a decoder could burn out just the same. My one suggestion would be find the weakest LEDs you can find as these ones get fairly warm and blacking them out will probably cause them to burn out faster than a low wattage LED.
Cambus capable error free LED, $3 for ten pack.
Working and recognized by the w204.
T-Taps to wire the sidemarkers inline to the original harness.
Both lights working
Viola. Total cost about $3.50 if you have a collection of T-Taps on hand. Takes 15 minutes of your time. Plus you'll have 8 extra LEDs for replacing other markers if you want. Beats paying to send the sidemarkers back anyday.
