2012 Dyno Mode, Traction aids still on?
Old 09-05-2012, 11:21 AM
CL66's Avatar
CL600
Was helping a buddy out with his 2012 c250 4matic he wanted to see how it would drive in dyno mode.
Got into the dyno mode enabled it. It said everything was off and showed all the indicators on the dash, abs was off too. So I'm pretty sure I was in the right dyno mode.
So we go to the track throw it into a turn and traction or stability is still on. Even though every light on the dash says everything is off. Am I missing another setting or just dreaming that dyno mode actually turns everything off?
With dyno mode on will the car get sideways? Can you throw it into a turn? Doesn't seem like it.
Old 09-05-2012, 06:22 PM
jctevere's Avatar
2012 C250 Coupe
Considering that a C250 is not offered in 4matic... I am curious as to if this story is completely made up or something. Dyno mode (in my 2012 C250) has turned all aids off. Nothing has noticeably kicked back in for me when I tried doing burnouts and drifts...
Old 09-05-2012, 07:32 PM
CL66's Avatar
CL600
There is a c250 4matic in Canada no turbo with 6cyl/7spd. Damn so maybe there is a setting I'm missing then for sure. When you are in the dyno mode menu you just enabled it that's it? No other setting you switch off/on?
Quick Reply: 2012 Dyno Mode, Traction aids still on?
