W204 2008 Aerial / Antenna Poor FM
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
hi, as the title says i am having poor signal issues with my comand unit
i have removed the unit and checked the wiring all seem ok.
i then removed the rear interior light and that seems all ok i can see 2 wires going to the shark fin and another with with a plug onit going to a black back which is located to the left of the shark fin
does anybody have any ideas on why my signal has started to degrade?
and how i can fix this,
Thank You
Thank You
2009 C300 4Matic Sport
This is a tough one.
I don't think the antenna is the problem.
It seems to me that it's a receivers issue. I know that's not what you want to hear/read. You should try resetting your command, or disconnecting the battery for a few minutes.
Hi, thanks very much for your replies, I will reset my comand before I head to work and monitor it on the drive to and from work, I will then post back the results, thanks again
