Rear LED signal light problem
Old Nov 6, 2012 | 10:53 PM
steeven001's Avatar
05 MB E320 CDI
Hey all car is a 2009 C300 4Matic has rear LED turn signal lights.
I had the bulb board and connector burn out on the right side so I replaced those. Now the problem I'm having is the right LED signal blinks once or twice then switches to the bulb above the LEDs (I think this is the marker light) and uses that for a signal instead. It does this every time I signal right and I'll get the check rear right signal error on the dash. I don't see any blown LEDs.
Any ideas?
Old Nov 6, 2012 | 11:21 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Any ideas?
The unit you installed shows as open to the lamp out sensor. The switch to the other bulb is normal and will continue until you correct your connections.
Old Nov 6, 2012 | 11:22 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Your solution:
https://mbworld.org/forums/c-class-w...led-turns.html
Old Nov 6, 2012 | 11:24 PM
RLE's Avatar
RLE
Originally Posted by dcjwlee
True, but a little pricey rather than just correct an installation error.
Thanks for mentioning it, though.
Old Nov 7, 2012 | 12:07 AM
steeven001's Avatar
05 MB E320 CDI
I don't understand what you mean. The parts I replaced have the same part numbers as the originals and I did each wire one by one not to get them mixed up.
