Upgrade to HIDs or stick with halogen low beams?
2010 Arctic White C300 4matic Sport
Hey everybody, it's a pleasure to join this forum.
To those of you who have upgraded your factory halogen low beams to HID/xenons with a plug and play kit - are you happy? How is the beam pattern and cut off? I have read mixed things while searching through the forums. Is your overall light output increased compared to the factory halogens?
Thanks!
Thanks!
1 Post
2012 C200 CGI
i have a 2012 and upgraded to a 'plug and play' hid kit. Got 6000k 'chinese brand' Enlight kit, initially didn't get capacitators as the lights didn't throw an error, but I found the light temp to be way too blue without them and it had a slight flicker in color temp that became a nuisance. After installing capacitators, the light became a pure white and no clicker what so ever.
The halogen beam cutoff on these cars are amazingly clean, one of the best halogen beam cutoffs I've ever seen. Obviously not as 'sharp' as a projector, but I found no issues of stray light blinding drivers.
I got the 35W HIDs and the light output is incredible! I wanted 55W at first but ended up deciding against it as I didn't want to test the idea of overheating the oem wiring.
If I'd have to choose again, I'd probably go with a 5000k hid for a slightly yellowish light to look more OEM than the pure white the 6000k's give me.
2010 C200 CGI
Thanks!
Thanks!
It would help if you specified if you were talking about the old version or facelift model. While not optimal, at least the old version halogens had projectors which not only focused the light but reduced most possible glare issues the reflector would have. I know we have members who swear that their facelift models with plug and play kits don't blind drivers and I'm sure the new reflector designs are great but I'm sure there are still glare spots, probably just minimized as technology and design gets better.
2010 C200 CGI
Great to hear that you are having a good experience even with reflectors. My biggest concern is that since the lights (whether pre-facelift projectors or post-facelift reflectors) are designed for halogen optics, that there would be too many flat spots, uneven cut offs, etc.
1 Post
2012 C200 CGI
For some reason my HID in reflectors are much brighter than oem projector hids. My headlights are so much brighter than my dad's OEM HIDs on his new Eclass
I'd say go for it, you will definitely NOT regret about the brightness and light pattern.
Hey check out this thread, I posted a video and a picture showing the cutoff with my HID Kit.
https://mbworld.org/forums/c-class-w...eadlights.html
Here is the cutoff picture.
