What does this mean?? (!)
Old Dec 12, 2012 | 01:42 PM
KAC300's Avatar
C300
Hey, I have a sign that kind of looks like (!) light up in the dash. I was wondering what it means, thanks in advance.
Old Dec 12, 2012 | 01:46 PM
lbmazdaspeed's Avatar
2009 c300 4matic P1
Its the tpms system, you need to put air in your tires, the correct tire psi is on the driver side door, there is sticker that tells you how much air you should put for front and rear tires.
Old Dec 12, 2012 | 02:06 PM
aMsupp's Avatar
C300 Sport
Correct.
Old Dec 12, 2012 | 07:39 PM
KAC300's Avatar
C300
Thank you. I greatly appreciate it. Everyone is pretty nice on this forum compared to the acura forum I used to be on.
Old Dec 12, 2012 | 07:40 PM
finger360's Avatar
2016 C63s AMG
I've also noticed the pressure in the door jam, but don't you usually follow the psi that is stated on the tire?
Old Dec 12, 2012 | 08:00 PM
glj12's Avatar
C300 Sport
No. What you see on the tire is the maximum supported PSI by the tire. What you see in the door jam is the correct weight, and should always be less than that of the tire. Follow what the door jam states for best performance. Cheers.
Old Dec 12, 2012 | 08:14 PM
Doanster's Avatar
C300 Sport 6MT
Are you talking about the yellow triangle exclamation point in the dash or does the symbol show up on the tach display? TPMS would be the flat tire symbol with the exclamation point. The yellow triangle flashing means traction control engaged or if steady, you have a DTC thrown.
Any msgs stored?
Old Dec 13, 2012 | 08:09 AM
memphis c350's Avatar
2008 mercedes c350
I thought that was the traction Controle
Old Dec 13, 2012 | 08:52 AM
aMsupp's Avatar
C300 Sport
The TCS is a /!\ that appears (obviously) when you break traction.
The TPMS is a {!} that appears in the dash cluster when your tire pressure is low (obviously). It does not go away until you fill to the correct tire pressure.
Old Dec 13, 2012 | 10:45 AM
holeeshht's Avatar
2012 Luna C
I always thought that symbol meant I was on alert like solid snake.
