Hesitation on turning over
Over the past few days I have noticed my car hesitate when i turn on the car in the morning or after it is been sitting awhile. The light on the dash will dim temporarily and then it will turn over. When but if after it has started or been driven for a min or two it turns over immediately. Think this is a batter issue?
Also a few times over the past month there has been the issue of I will insert the keyfob and the steering will wont unlock and wont turn on at all but if i pull the key out and try again a few times it will work fine. Not sure if they are related in any way.
Hopefully it is was just a low battery since i take a lot of short trips to and from work of about a mile but if it is a failing ignition i guess it will be their issue since i still have factory warranty for another couple months and then extended warranty until 2016.
Hopefully this will truly fix the problem and not just mask it for awhile.
