Ground on hid ballast
two things struck out, no size drill suggestion for the rubber grommet hole and the ballast mount part has a ground seperate wire?
I've never seen a ballast with a need for ground and obviously the supplier is on christmas break
Any ideas of a usual rubber size grommet drill bit and do ballasts need grounds/earths?
The hole was eventually done at 3/4 because the inner ring of the grommet was at 3/4. Had I drilled it at 1 inch the grommet would have fallen straight through. and given my skills there was always a chance I would screw it up
Thankfully the hids were on the mrs mercedes and it has earned me enough brownie points to go fat biking tommorow
thanks for the input chaps
