Record of warranty work done on 2009-C230 4MATIC to-date. How does yours compare?
Work covered by Warranty to-date: Problem/Solution/Mileage.
- rough engine idle; replaced position sensor for right swirl flap; 7,294kms
- loud frame creaking noise from back seat; welded right rear susp tower; 7,294kms;
- wheels damaged by dealer on tire install; installed 4 new wheels; 7,294kms
- cracking on seat pan upholstery; replaced driver's seat cushion; 13,822kms
- driver side door trim loose; replaced door trim; 13,822kms
- premature wear on front pads and rotors; replaced; 26,230kms
- engine light staying on; replaced valve in fuel system; 32,146kms
- steering wheel rubbing through on top; replaced wheel cover; 32,544kms
- engine vibration when car in idle; replaced engine mounts; 35,839kms
- CD player not operable; replaced command unit; 37,836kms
- right and left signal light reversing; replaced steering module; 42,200kms
- chirping noise from heater; replaced heater blower; 42,200kms
- loud engine chirp and grind on cold start; eplaced belt tensioner and idler pulley; 51,222kms
