Changed engine air filters....
Old Feb 2, 2013 | 09:34 PM
NorcalMark's Avatar
C300
Now I have a check engine light. I knew this could happen.
How do I get rid of the check engine light? I made sure the intakes were on correctly and the cover was on correctly. All looks good.
If searched this forum and the internet and cant seem to find any info.
Mark
Old Feb 2, 2013 | 11:10 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Make sure the back of the cover where the throttle body meets is pressed down all the way. It almost pops into place.
Old Feb 2, 2013 | 11:47 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
+1 re check everything, not having the air boxes properly seat in its orignal configuration will throw a light
Old Feb 3, 2013 | 12:12 AM
NorcalMark's Avatar
C300
I will try it again.
If everything is in its proper place and fitting like its supposed too, they light should go off?
Mark
Old Feb 3, 2013 | 12:19 AM
E350 Sport/ML350RWD
Hopefully. The airbox assembly/throttle body seal is usually the problem.
Old Feb 3, 2013 | 08:27 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
That does seem to be the one area where everything can look good but just not be "snapped" completely into place.
Old Feb 3, 2013 | 09:32 AM
NorcalMark's Avatar
C300
Thanks for the help fellas. Still having a bit of an issue. Im gonna try it again later this morning.
Old Feb 3, 2013 | 10:18 AM
E350 Sport/ML350RWD
Make sure the hose on the front is reconnected. When you reinstall the airbox assembly- start in the rear middle where the throttle body intake is. Set that first and then work your way forward. All other clips are simple retaining clips. The important thing is that the assembly is firmly set in to the throttle body.
Old Feb 3, 2013 | 04:35 PM
Bosnia1992's Avatar
2018 C63s Coupe 2016 C450 DAILY
if the error light is on. before its off, go to settings and set to factory settings turn car off and back on, if everything is how its supposed to be it should go off. Just trying to fix it won't turn off the light even if its how its supposed to be , system has to update it . hope it helps
Posted from Mbworld.org App for Android
