Mounting H7 Load Resistor
I recently mounted an H7 load resistor for my fogs. Something like what you see below:
I found the perfect spot for the load resistor, on a vertical metal bar. I mounted the load resistor with zip ties, similarly to what I did with my ballasts for my HIDs. Will this work just as well as screws in terms of heat dissipation? I'm unsure of the difference between this, and screws since it has a flat, metal, contact.
Let me know what you guys think. And if it does need to be screwed down, how could I do that by the fog lights?
Thanks!
