Power steering
Old Mar 4, 2013 | 04:27 PM
Bosnia1992's Avatar
2018 C63s Coupe 2016 C450 DAILY
Power steering
I've noticed when turning barely when driving it is a very loud noticeable whining noise, or even when I accelerate sometimes the car will whine . if I turn toouch it sound like a popping whining noise. I checked the fluid and its fine. Any idea ?
Posted from Mbworld.org App for Android
Old Mar 4, 2013 | 11:34 PM
Bosnia1992's Avatar
No one has any idea ?
Old Mar 5, 2013 | 03:57 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Jack up the front end & try to replicate the noise turning the wheel with the engine running , bonnet open & your head inside.
Old Mar 5, 2013 | 07:42 PM
Bosnia1992's Avatar
I did replicate it. same thing even on Jacks . anyone have any idea ? pump might be going out ? transfer case ? torque converter whining ?
Old Mar 5, 2013 | 08:48 PM
Domm's Avatar
'08 Mercedes C300
I think I remember Glyn mentioning something about this (don't quote me on this). The power steering is really sensitive to even a slight decrease in fluid. Try topping off and turn your wheels left and right 5-10 times to remove any trapped air.
Old Mar 5, 2013 | 09:11 PM
Bosnia1992's Avatar
Thanks domm,
I've done that and no luck, pump is probably going out or the bushings or whatever they're called. Anyone expierence a whine when accelerating? I know its not normal to be very loud.
Old Mar 5, 2013 | 10:15 PM
Samaral's Avatar
2014 ML 350 BT
Could not be the belts??
Old Mar 5, 2013 | 10:29 PM
Bosnia1992's Avatar
I've had all my belts and pulleys replaced due to a squeak. its a whine now.
Old Mar 5, 2013 | 10:37 PM
Samaral's Avatar
2014 ML 350 BT
I have a Toyota 4Runner that had this constant whine and it was the alternator. I believe something to do with bearings.
Old Mar 6, 2013 | 01:09 AM
Carsy's Avatar
Time to pull out the old stethoscope. Just be sure you do not catch it in the belt & pullieys.
