Check tire pressure?
2 days ago, driving down casually then the dashboard turned red stating "Check tire pressure". This got me worried, and scurried back home and checked the tires straight away, but found nothing at all. Nothing seems to be amiss, but took a precaution anyway and drove another car yesterday to work to see if a flat tire might come by. Got home from work, but still the tires were fine
.I started the car, and it says "Reset tire pressures after changing?"
Well, I did reset it from the menu and drove around a couple of short distances but nothing still. Am I having an illusion ? lol
Does it mean that I am resetting the sensors since I put new tires in?
Why did it sense the new tire late though (after a few weeks of use)?
The best way to reset your tire pressure is to let you car sit, preferably overnight, and then check and adjust your pressures to what is on your tire pressure placard/sticker.
Once everything is correct, then save your settings. If you just randomly save your setting when your tires "look good" you could have them at 5 or 10 or more PSI off without even knowing it.
